R56 Coolant temp sensor going bad
Old Jan 17, 2022 | 03:13 AM
Germinisr56's Avatar
Germinisr56
Hello guys . Just asking for a little little help. I have an 07 cooper s turbo 6 speed manual the issue is I have went through 5 coolant temperature sensor already and they keep failing . also I have replaced the thermostat housing as well . She runs perfect for a week and then the fan kicks early mornings.
Old Jan 18, 2022 | 02:05 PM
Most of the time its the coolant system not being bled all the way and you get temp sensor errors, running too hot or cold. Its too low in the thermostat housing It takes a couple hot/cold cycles to get the air out.
https://www.northamericanmotoring.co...8-no-heat.html
El_Duderino
Mar 31, 2019 09:23 AM
Martin Platek
Nov 22, 2018 10:35 PM
Grenadearmy0299
Jun 28, 2012 03:44 PM
idickers
Mar 10, 2009 03:26 PM
stever
Mar 22, 2005 08:26 PM
