R56 Battery negative terminal briefly disconnected. Re-registration required?
Old Jan 6, 2022 | 03:42 PM
David MacNeill's Avatar
David MacNeill
I was putting on a terminal extension to my battery so I could more easily attach it to my Battery Tender, and the negative clamp slipped off for a few seconds. Do I have to re-register the battery with the car’s computer now?
Old Jan 6, 2022 | 06:17 PM
bagwell's Avatar
bagwell
Gonna say no, not necessary.
Old Jan 6, 2022 | 06:20 PM
thefarside's Avatar
thefarside
Re-registration is only necessary if the battery is replaced with a dis-similar battery, i.e. different CCA, Ah and/or type.
Old Jan 6, 2022 | 06:33 PM
David MacNeill
Thanks guys. I’m not ready to replace this battery yet, but when I do I’ll be sure to code it correctly with BimmerLink/BimmerCode and the abundant sage advice on this forum.
Old Jan 6, 2022 | 09:15 PM
giorgos's Avatar
giorgos
Just in case someone who is not aware of the difference between a "battery reset" and a "battery registration" is reading this thread:
- When replacing a used battery with a new one of the same capacity, a battery reset is required.
- When installing a battery with different capacity from the capacity value stored in the car's ECU, a battery registration is required.
Re-connecting the same battery does not require either of the above, as long as the battery's charge holding ability has not increased (e.g. by reviving it) or significantly deteriorated while disconnected.
Also: batteries in cars with an IBS sensor should not be charged without the charging current flowing through the IBS sensor.
Wanderlustsrt
Jan 31, 2017 04:05 PM
Red Rhino
Oct 30, 2007 07:19 AM
