DSC light coming on under hard acceleration
Old Nov 25, 2021 | 12:00 AM
Advinnie's Avatar
Advinnie
Hi all my name is Adam and im new to this forum, so hello to everyone on here.
now I have a 2006 JCW with one little problem and that’s the DSC warning light coming on and staying on. Now if I drive the car normally all is good, even if I go WOT but change gear by 5000 rpm all is good BUT if I go and have some real fun in it and go WOT to red line (6500 rpm in my case cause im running a 20% S/C pulley) the DSC light comes on and stays on and can not be turned off by the switch, the only way to turn it off is to turn the ignition off and remove the key then restart the engine and all is good again until I go mad with her again.
now if under normal driving and I spin a wheel the DSC light will come on briefly as it cuts power then goes back out. It only stays on when you really having fun with the car.
many ideas on what’s going on?
I do have a C110 scanner and it’s not showing any codes at all
Old Nov 28, 2021 | 02:53 PM
TVPostSound's Avatar
TVPostSound
Soon the wheel and DCS goes on =Normal
DSC stays on:
Check the brake fluid level.
Low brake fluid sensor will trigger DSC issues.
staudacher
Jun 5, 2018 05:40 AM
Martin Brenneke
Aug 5, 2012 12:12 PM
jay80424
Jan 30, 2008 08:01 PM
Jeffy
Aug 26, 2005 05:33 PM
