09 r55 turbo Fried DME?
Old Nov 22, 2021 | 03:25 PM
Nitro91jj's Avatar
Nitro91jj
Long story short I had the coil ground wire disconnected, and connected it while the engine is running. It arced, then the car died. I tightened the ground wire, started the car right back up, but had a check engine light for codes 2bd4 and 2848. Codes won't clear, and it doesn't run very good (random stuttering on accel). I tested all fuses in engine bay and in passenger footwell and all are good. Am I looking at a fried DME? Anyone have any experience with similar? Car is a 2009 2 door 1.6l turbo mini Cooper S.
Old Nov 22, 2021 | 05:04 PM
thefarside's Avatar
thefarside
Looks like the 2bd4 code is an internal DME error indicating a voltage reference fault, translation: your DME is down for the count. You might want to see if there is anyone who can repair it as opposed to replacing.
Old Nov 22, 2021 | 07:07 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
ecu can be cloned but you need to find the exact same part number/revision to do it, and it has to be bench flashed. I did one, was not fun, also did immobilizer delete at the same time
Max Martin
R55 :: Clubman Talk (2008+)
Mar 19, 2020 06:19 AM
arnot327
Sep 17, 2019 05:31 PM
Turkeyboul215
Oct 3, 2016 08:00 AM
actasci
Feb 6, 2014 06:01 AM
