R55 fuse box question
Old Nov 8, 2021 | 04:28 PM
Collin Piette's Avatar
Collin Piette
fuse box question
Hello,
So I just a quick question. I ended up having to swap out my fusebox. Water damage of course. I managed to find a used one with the exact same numbers as the original. The only number that was different I would guess would be the production number. Anyways, my question is do I have to get the newer used fusebox programmed to my car even though numbers match? Everything seems to be working an no weird things happening or not working. Just thought I'd ask to make sure.
Old Nov 27, 2021 | 08:26 AM
Clockwork's Avatar
Clockwork
Correct me if I'm wrong, but isn't the fuse box just a plastic housing FOR fuses and relays to sit OR is there a module built into the box? I'd THINK that you'd not have to get anything coded/activated...
Old Nov 27, 2021 | 09:08 AM
Collin Piette
That’s exactly what I thought as well. But doing further research into it, you do have to get them programmed if some the electrical systems go wonky with a used one if the part number doesn’t match or is a brand new unit. At least that’s what I’ve gathered.
poolemac
Electrical
12
Mar 7, 2019 07:54 PM
slayerx02
Oct 5, 2013 11:54 AM
rbb
Sep 24, 2011 11:29 AM
DME
Jan 2, 2009 02:35 PM
ImagoX
Classic Mini Talk
Jul 30, 2007 10:02 AM
