Belt tensioner on its way out?
Old Nov 1, 2021 | 01:58 PM
dayman's Avatar
dayman
Started hearing a chirping noise from the front of the engine while running, after popping the hood it seems like the belt tensioner is vibrating and moving a lot and seems like the noise is coming from there. Is it time to order a new belt tensioner assembly?
Video of the sound:
Replaced the idler pulley and supercharger pulley <15,000 miles ago.
Old Nov 1, 2021 | 07:13 PM
DFTR's Avatar
DFTR
Probably. Yeah. Check that mount while your at it.
Old Nov 2, 2021 | 09:18 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I know I'm hard of hearing but that sounds as smooth as a sewing machine. In the last few seconds, you can see the tensioner spring and it doesn't appear to be vibrating much at all. Suggest you carefully use a mechanic's stethoscope or a wood dowel placed to your ear to better locate your problem...if there actually is one.
Old Nov 2, 2021 | 10:21 AM
dayman's Avatar
dayman
I kind of see what you mean, I'll take a look again at the spring to check if its vibrating. However, in the video it seems like the metal bit that wraps around the top of S/C pulley is jumping around a bit and vibrating.
Old Nov 2, 2021 | 08:10 PM
Racingguy04's Avatar
Racingguy04
it's normal for the tensioner to move some, that's part of the design. It doesn't look or sound worn out to me, but it's often hard to tell in video, and I can't really tell without pulling the tensioner, or at least the damper and seeing how freely it moves.
philwarner
Dec 30, 2020 08:10 AM
Racingguy04
Feb 5, 2016 09:07 AM
Saltysalt
Jul 24, 2015 05:58 AM
Trashman
May 9, 2008 06:36 AM
phydeaux
Aug 14, 2007 12:07 PM
