R55 Balky Steering Rack on Re-install...
Old Jul 23, 2021 | 02:35 PM
e24mpwr's Avatar
e24mpwr
I finished my suspension install a while back, but upon buttoning it all up and pulling out of the garage, I found that I had maybe a quarter of the travel when I turn the steering wheel that I should have.
Background:
I replaced pretty much everything in the front - steering and end links, swaybar and LCA bushings (and the LCA's themselves), struts, etc. I dropped the exhaust and subframe to do all that since the Mini is an Origami car...
I did manage to pop one of the connectors for the rack as I was trying to line everything up (next time I'll have a friend/spawn helping... ) and it cracked one of the connector housings...
It looked cosmetic, so I popped it with some compressed air, installed the connector and put some electric tape around the outside guard against moisture/etc.
After the unsuccessful rollout above, I tucked it back in the garage and have been using it as an excuse to drive my old BMW.
Now I really kinda need the car back, and especially need to get it aligned/etc. before this time next week, so wondering if I've borked the rack.
Some other details:
  • It moves, stops and then feels like it's cycling or trying to move, but the wheels don't go anywhere.
  • Same behavior whether turning the wheel left or right.
  • From center, the wheel turns one half-turn either way. Hmmm...
  • No noises or anything strange.
  • I don't think I'm hitting anything. (except the half-turn thing...)
  • I'm not 100% sure I lined up the steering link to the wheel (i.e. returned it to the exact same position) but think I did.
Any help super-appreciated! (wondering if this will get more eyeballs in R56, and guessing all this stuff is essentially the same, but...)
Old Jul 23, 2021 | 03:21 PM
e24mpwr's Avatar
e24mpwr
Hmmm...
With the car in the air and the wheels off, I get more like 1.25 turns before things are limited...
So tires/wheels? They stayed the same?
I installed Koni Special Active struts BTW...
Old Jul 24, 2021 | 05:03 PM
e24mpwr's Avatar
e24mpwr
As it turns out, I had the steering end links swapped, so it was fouling on the wheel. I swapped 'em, and problem solved!
tragedybysyntax
Dec 1, 2015 08:54 PM
mikewitdaspike
Classic Mini Talk
Feb 23, 2013 04:32 AM
starionturbo
May 11, 2011 07:35 PM
smalest
Classic Mini Talk
12
Aug 16, 2010 01:01 AM
Aeromax
Jun 17, 2010 09:11 AM
