No Tach signal or Speedo after rebuild
Old Jul 12, 2021 | 08:27 AM
07 MINIKO's Avatar
07 MINIKO
Hello folks, i just rebuilt the engine in my 2007 R56 base, upon initial start up the engine runs, (rough idle), but wondering what sensor/s would effect the tach, and Speedo. Was able to drive it around the house and verified that the speedo is not working, and it seems to have limited power. I assumed that the inoperable tach is causing some of the other issues. Please advise... I have not bought a scan tool yet, and would like advise on which one is good but not too costly...
Thanks all for the help!
Old Jul 27, 2021 | 10:07 PM
avarath's Avatar
avarath
Perhaps the crankshaft sensor? Though I was under the impression your car won’t start with a bad crankshaft sensor. I believe it also doubles as the engine rpm tachometer. You could have a bad sensor, reluctor wheel, or faulty wiring or connectors/pins could be impeding a proper signal to the computer.
autozone should be able to scan your codes for you, though perhaps it’s also one of the tools they rent out if you can’t make it out to their store with your car. It’s worth checking.
Roger Winright
Dec 18, 2017 07:12 AM
mlivvy
Jul 19, 2015 10:53 AM
IslandMiniS
Nov 26, 2013 05:23 AM
mwittstock
Apr 24, 2008 06:57 AM
bee1000n
Mar 23, 2008 10:08 AM
