How To Anyone want to help me program for my 25w Xenon retrofit lights?
Old Jun 6, 2021 | 07:22 AM
sirmoog's Avatar
sirmoog
Hi, I have seen a number of posts for folks successfully programming their Xenon retrofit lights with NCS software. I am not super tech savvy, but I would offer to Venmo someone the $100 to walk me through step by step, instead of giving that money to the dealer. Let me know! I have a 2010 Clubman S.
Old Jun 6, 2021 | 09:00 AM
scotty_r56s's Avatar
scotty_r56s
Put that money towards the Bimmergeeks Protool app and their K+DCAN cable. You will be able to program your lights and you will have the ability to diagnose almost any issue before going to the dealership.
Old Jun 6, 2021 | 09:06 AM
sirmoog's Avatar
sirmoog
thanks! I will buy those things, but am really worried about screwing up the coding. Reading codes are a different story. I need hand holding!
Old Jun 6, 2021 | 09:11 AM
scotty_r56s
If you get the app and the cable, shoot me a dm. I will walk you through it for free. Things like that shouldn't cost money lol.
Old Jun 7, 2021 | 06:56 AM
sirmoog's Avatar
sirmoog
Very cool, I can at least offer to buy your family dinner or something! I'll just now need to figure out how to DM...
Do you know, is that app only for Android devices?
Old Jun 7, 2021 | 07:00 AM
scotty_r56s
It's only available on android at this time. In my opinion, it is worth picking up a cheap or used Android tablet or phone just for this tool.
Old Jun 7, 2021 | 07:40 AM
sirmoog's Avatar
sirmoog
Thanks! Got a drawer full of old ones, I'll try to get one to work!
Old Jun 7, 2021 | 09:17 AM
sirmoog's Avatar
sirmoog
One other question on the Bimmergeeks products. Do you know if both the Bluetooth adaptor and the K+DCAN cable are required, along with their app, or is it just one or the other?
Thanks!
Old Jun 7, 2021 | 09:19 AM
scotty_r56s
Thanks!
I've only used the K+DCAN. I've had mixed experiences with K+DCAN that I have found on Amazon, but the Bimmergeeks cable has worked great. You should only need one or the other.
Old Jun 7, 2021 | 09:25 AM
sirmoog's Avatar
sirmoog
Awesome!
Old Jun 10, 2021 | 03:22 PM
scotty_r56s
Here is quick DIY for the Bimmergeeks Protool:
1. Tap "Vehicle"
2. Tap Vehicle Order.
3. Tap Edit
Note: You will be prompted to save a backup of the Vehicle Order.
4. Select Add-Ons.
5. Select X25W: RETROFIT 25W XENON HEADLIGHT NA 190572
6. Select Actions.
7. Select Save.
Note: You will be prompted to code modules that are related to the changes made as well as the CAS and FRM.
8. Return to the main menu.
9. Select Safety.
10. Select FRM.
11. Select Coding.
Note: you will be prompted to make a backup.
12. Select Standard.
13. Change the following:
a. Cold Check High Beams
b. Cold Check Low Beams
c. Left Lwr Error
d. Right Lwr Error
e. Hot Check Hight Beams
f. Hot Check Low Brams
g. Xenons Installed
14. Select Finalize.
Note: You will be prompted to cycle the ignition.
That should do it.
Old Jun 11, 2021 | 05:23 AM
sirmoog's Avatar
sirmoog
1. Tap "Vehicle"
3. Tap Edit
4. Select Add-Ons.
6. Select Actions.
7. Select Save.
9. Select Safety.
10. Select FRM.
11. Select Coding.
c. Left Lwr Error
d. Right Lwr Error
g. Xenons Installed
That should do it.
This is unbelievably helpful!! Thanks for taking the time to help out me and the community!
Old Sep 25, 2023 | 02:17 PM
Yoshimura 1's Avatar
Yoshimura 1
This is great .......I'll be getting this to code my lights
Old Sep 27, 2023 | 08:07 AM
DogfaceSGM's Avatar
DogfaceSGM
Curious if you have used BimmerLink/BimmerCode and how does BimmerGeeks Protool compare? More functions/coding or ease of use etc.
I have BimmerLink/Code and so far it has done 99% of what I wanted to do. The only thing I have done with NCS Expert is correct my speedo.
Old Sep 16, 2024 | 03:59 AM
DogfaceSGM's Avatar
DogfaceSGM
I got the app and their cable but it isn't able to read my VO. What version of the app are you using? I am on 2.52.7
I have tried it with auto detect, R5X series, connecting and powering differently about everything I can think of including setting the vehicle back to factory with NCS Expert yesterday and it still will not connect. I have BimmerCode nd BimmerLink on the same tablet and they connect no problem.
I searched their FB page and didn't find a similar issue, submitted the question and about the only response I get is what version am I using.
erviv
Nov 16, 2013 04:57 AM
Cutting11S
Jan 16, 2011 05:24 AM
esgam
Sep 10, 2007 08:11 PM
Jtrem
Oct 22, 2006 07:08 PM
