OEM 2nd Gen LED Fog Lights
For SaleLights
Price
$100
- Location Rochester, NY, 14420, USA
- Condition Used
- Compatibility
| Make | Model | Year |
| Mini | R56: "Mk II" Mini Hatch/Hardtop range | Any Year |
| Mini | R55: "Mk II" Mini Clubman | Any Year |
| Mini | R57: "Mk II" Mini Convertible | Any Year |
| Mini | R58: Coupe | Any Year |
| Mini | R59: Roadster | Any Year |
Recently removed LED fog lights from my R55 Clubman. These were installed for ~4 years, so they have some "wear" on the lenses. After less than a year of use, the LED DRL ring on one side decided to no longer work properly. Initially, instead of replacing the light, I opted to disconnect the DRL trigger wire, and run these in "Fog" mode for DRL. Ran it like that for the past 3 years with no other issue. Decided recently that I wanted something different, so I removed the kit, and here you have it.
This kit is no longer available as a boxed set from Mini. When it was available, the kit could be purchased for ~$350 or so. ECS will sell you a pieced together kit for $437 with new components. I'll sell you my used kit for $125 plus shipping. (less than the cost of a new control module)
DRL mode. One light ring does not illuminate as described.
Running light mode. Position 1 on the light switch.
Fog lights illuminated. Ran my DRLs in this mode for the past few years.
