2011 r56 jcw
2011 Mini R56: "Mk II" Mini Hatch/Hardtop range
  • 2011 Mini R56: "Mk II" Mini Hatch/Hardtop range - 2011 r56 jcw - Used - VIN WMWSV9C55BTZ96982 - 94,500 Miles - 4 cyl - 2WD - Manual - Hatchback - Blue - Rustburg, VA 24588, United States
    $7,000
  • Location Rustburg, VA, 24588, USA
  • VIN WMWSV9C55BTZ96982
  • Mileage 94,500
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Blue
The things done:
 Rebuilt engine with forged rods and pistons including timing, vanous and vacuum pump
 JMTC 42mm turbo
 New injectors
 Spec stage 1 clutch with new flywheel and new clutch release fork
 AEM intake
 Custom catless exhaust with magnaflow muffler and an old volvo resonator to remove drone
 BC coilovers
 Firmer control arm bushings. Powerflex?
 Oil catch can installed
 Strut brace
 Some things coded with BimmerCode and that will included
 The bad:
 Tyres are pretty much done for
 The drivers door latch is a bit difficult (outside)
The footwell module is sorta wonky even though Xemodex couldn’t find anything wrong. (Headlights sometimes don’t turn off on auto setting and the alarm will always go off if locked with the sunroof open)
 Cosmetics aren’t great, RH front fender flare has gone, paint chips on the front pieces of the kit-the paint used will be included
 The title is rebuilt from being crashed. I bought it wrecked and fixed it. Rebuilt is different than salvage so you should not have any issues with licensing and insurance.
 Theres probably a few things im forgetting. I haven’t been running it much in the last few months. My original plan was to build it up of sorts into a moderate track car. But I found I’d rather do that with an R53 which I recently gotten
