Clutch Pedal doesn't line up with clutch stop.
Old May 2, 2021 | 05:47 PM
iDriveR56's Avatar
iDriveR56
I just bought my first Mini a 2012 S with ~40k miles a few weeks ago. One of my first complaints is a common one, the clutch pedal travel. After scrolling the the forums and seeing the BMS clutch stop and the few DIY examples, I decided to squeeze down there and take a look at things for myself and found that my clutch pedal seems to miss the clutch stop completely and digs into the foam(?) thats on the floorboard
. I had already removed the stock stop when I took the picture. So is my clutch pedal bent? Will the have an effect if I extend the stop either BMS or DIY? Is there any way to rectify this?
Old May 4, 2021 | 06:33 PM
NeonLed's Avatar
NeonLed
The clutch pedal is plastic so it will break if you're able to bend it. But it will hit the foam on the firewall before the stop. So if you really push down on the pedal then it will hit the stop. I put the BMS in my car and the diameter of it is much larger than the stock one so it hits the stop before the foam on the firewall.
Old May 4, 2021 | 07:15 PM
iDriveR56's Avatar
iDriveR56
Awesome thanks for the reply, I just don't wanna waste, even a few bucks, if my pedal wouldn't even hit the stop and continued to dig into the foam. Guess I'll be deciding on which route I wanna go the couple bucks or $10+shipping. Thanks again!
TWISTER
Apr 18, 2016 05:35 AM
jamfred774
Apr 14, 2015 07:47 AM
Kennedy
12
Apr 3, 2008 09:31 AM
MiniJayhawk
Nov 1, 2007 11:57 AM
bambam
Aug 23, 2007 08:44 PM
