Looking to buy a left side R52 Xenon headlight assembly
Wanted
Audio Video/Electronics
  • Closed
    $1 - $200
  • Location Charlottesville, VA, 22968, USA
  • Compatibility
Make Model Year
Mini R52: "Mk I" Mini Convertible 2005 - 2007
My 2005 R52 S left (Driver side) headlight is broken, and pointing down. I'm looking for a replacement assembly.
Old Mar 22, 2021 | 02:18 PM
RB-MINI's Avatar
RB-MINI
Your headlight might be repairable. The projector xenon lights pointing down are usually because a ball joint inside the headlights popped loose from slamming the hood or hitting potholes. There are two and they can sometimes be popped back into place through the back cover without without taking the headlight apart.
Projector adjustment connected at 3 o'clock position looking into opening.
Projector adjustment popped loose at 9 o'clock position looking into opening.
Old Mar 22, 2021 | 02:37 PM
Cobre's Avatar
Cobre
You're the first one that has posted pictures good enough for me to understand!
The ball and socket have come apart, but I'm not sure how to put them back together without breaking them. Do I just push them together? Do I have to take off the snap ring, and if so, how in the world do you get it back on?
EDIT: Got it fixed, thanks so much!
