Difficulty going into reverse
Old Feb 7, 2021 | 05:57 PM
WolfUSAR's Avatar
WolfUSAR
Hello everyone,
R50 w/ 5 speed. So every now and again, when I try to shift into reverse, the shifter will not go down into reverse unless I let out on the clutch a little. Is this an adjustment issue? I haven’t had time to crawl under and find out, plus this is my first manual trans carso I really don’t know what I’m looking at
Old Feb 7, 2021 | 11:03 PM
Dan_in_WA's Avatar
Dan_in_WA
To the best of my knowledge this isn’t a problem. Someone else may know more.
There’s no synchro on Reverse, although it should engage with little effort from a standing stop.
One thing to try would be to change the gear lube. Mine’s going back together after a trans and suspension overhaul and I put Redline MTF in it, no miles yet but I’ve heard good things.
Could be that your shifter cable(s) need to be cleaned and lubed.
There’s two cables. Have an assistant push in the clutch and run it through the gears while you watch what the linkage does.
Watch the shift rod that goes into the transmission: It will move up and down as well as around. IIRC, the 1-2 shift is at one height of the rod, the 2-3 shift is in the middle, and the 5 - Reverse is at the other end of the vertical travel.
Old Feb 8, 2021 | 11:57 AM
deepgrey's Avatar
deepgrey
It’s just the spur gears for reverse not matching up while stationary. Every manual I’ve ever owned has done that occasionally.
Old Feb 8, 2021 | 12:06 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
^This
As was mentioned, if this ever happens, put the shifter in neutral, let out the clutch pedal, push the pedal back down, then try reverse again.
Old Feb 8, 2021 | 01:39 PM
mrbean's Avatar
mrbean
^This again.
My E46 did it all the time. If I shifted into 2nd before going into reverse it solved the problem. For some reason I found this easier than pumping the clutch pedal.
Old Feb 9, 2021 | 03:17 PM
WolfUSAR's Avatar
WolfUSAR
Thanks everyone, just my paranoia I guess. My only real experience with a stick shift was a Mitsubishi Fuso Rosa I drove in Kuwait while I was on deployment (when I wasn’t in Iraq) for a year. Not much to compare there
Old Feb 10, 2021 | 11:03 AM
Yep, mine does this, so you push in the clutch, wait a few seconds then slowly put it back into reverse. If not try again.
AdamT
Jun 20, 2009 05:59 AM
Regina
May 22, 2007 09:32 AM
ahamos
Aug 12, 2006 04:42 AM
jsun
Sep 28, 2003 09:32 PM
