Navigation & Audio Location for Front Speaker Crossovers?
Old Jan 2, 2005 | 01:33 PM
62Lincoln's Avatar
62Lincoln
I've read posts in the past that show crossovers mounted on the inner door sheet metal just aft of the speaker location. However, I think these installs were on '04 and earlier models. I have an '05, and the backside of the interior door panel appears to have some added reinforcements that are causing me to question whether or not there will be enough space for the crossover to fit.
Has anyone done an install on an '05? Did the backside of the interior door panels change, or am I just not seeing straight? For details, my front speakers will be Boston Acoustics 6.5 Pro's along with the crossovers, of course. And also will use another set of BA tweeters in the stock location.
Thanks for any advice or input you can offer!
Old Jan 2, 2005 | 06:02 PM
foko's Avatar
foko
Inside the doors is a bad choice for crossovers, primarily because they can get wet in there. Thats ok for a while, but i've seen some pretty badly oxidized crossover components after a year or so in a door. Additionally theres a modest amount of "shock" everytime you close/slam the doors. Quality crossovers can probably take it ok, but i don't like to chance it.
I put my Dynaudio crossovers in the space inside the small hatches in the boot.....basically right up against the taillight assemblies. Theres lots of room in those compartments....I've got the crossovers, and two processors in there without problems.
The downside with that location of course is running more speaker wire.
Good luck,
Fabian
Old Apr 14, 2005 | 06:06 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I'm sorta new to audio, i just installed my HU without any problems though
Is there a huge downside to running a wire that far? I was thinking about powering the crossoves from my HU's built in amp, so i would have to run the wires all the way back up front wouldn't i?
Old Apr 14, 2005 | 05:07 PM
foko's Avatar
foko
Well, you do have to run a lot more wire if you are using the HU power and put the crossovers in back. As a general rule, you want short wire runs for everything. Space limitations for components frequently override such general rules though.
I would try to stash crossovers up under the dash somewhere in your application. There's lots of room in there, you just need to be creative about mounting (quality double back tape and/or velcro and/or zip ties all work great)
Old Apr 14, 2005 | 05:27 PM
memojo's Avatar
memojo
In the boot
I had my crossovers put where the HK amp was (before we pulled it out). New amp is on the boot floor above the battery. Works well.
Memojo
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 15, 2015 11:20 AM
joelcseymour
Aug 7, 2015 12:43 PM
OutMotoring
Aug 6, 2015 09:32 AM
