R56 2009 Convertible Roof Issue
Old Jan 29, 2021 | 12:24 PM
ronald polichnowski's Avatar
ronald polichnowski
All of a sudden the roof when down does not want to go back up. When the button is push you can hear the mechanism engage. If my wife grabs a corner and gives it a little help, the roof will pop right up. Strange as at first I thought something was stuck but happens continually now. Just an FYI - the car sat unused for 6 months but not sure that has anything to do with the problem.
Old Feb 2, 2021 | 10:29 AM
Maybe the joints are sticking and need grease, those are the scissor joints. Or you have a weak battery, That can do it also.
Old Feb 2, 2021 | 11:47 AM
Fly'n Brick's Avatar
Fly'n Brick
+1 on the scissor joint lube on a regular basis. They'll tell you when with an annoying squeak. To prevent crud build up use a dry lube like Liquid Wrench. Go with a battery check as well.
MrElusive
R57 :: Cabrio Talk (2009+)
Oct 17, 2014 02:15 PM
eyevin68
R55 :: Clubman Talk (2008+)
49
Jan 29, 2009 05:58 AM
MiniTude
Jul 5, 2007 02:01 PM
