2003 Mini Cooper S JCW (motor blown)
2003 Mini Cooper
  • 2003 Mini Cooper - 2003 Mini Cooper S JCW (motor blown) - Used - VIN wmwre33493TD66454 - 85,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Blue - Boca Raton, FL 33428, United States
    $1,900
    • OBO
  • Location Boca Raton, FL, 33428, USA
  • VIN wmwre33493TD66454
  • Mileage 85,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Blue
Come and get it. LOL. 5 6 I. 3 5 O . 7 5 9 O
please text before calling. Thanks.
I can't spend money rebuilding the motor right now. My loss is your gain. Just spent a bunch of money on it.
New:
-Detroit Tuned Rebuilt Supercharger with 15% reduction pulley
-Detroit Tuned Bypass valve
-OEM Waterpump
-New WMW aluminum Thermostat housing
-New OEM thermostat, gasket and bolts
-ATI 2% Harmonic Damper
-Crank Seal
-Belt and Belt Tensioner
-Idler pulley
-A/C Compressor, Drier, EVAP
-valve cover gasket
-OEM passenger side engine mount
-CPS seal
Also has parts from previous owner installed:
-Rev9 Coilovers with adjustable front camber plates
-XXR wheels repainted white but done pretty poorly
Interior is very clean. Black headliner with fiber optic "twilight" effect. And some interior pieces are plastic dipped black.
It spewed our oil after getting a little into boost around 3k rpms in 2nd gear. I do not know what the motor needs, but it's probably nothing too simple.
Driver side door has to be manually unlocked and locked, and the driver window sometimes needs a slight door panel smack to want to start moving, but other than that, everything seems to work fine.
Sold AS-IS. Come pick it up or arrange for a car hauler to pick it up. Not sure what to ask for it.
Old Jun 7, 2021 | 12:34 PM
EvilMiniR53's Avatar
EvilMiniR53
Is this car still available?
