JCW Winter Rims from CLA?
Old Oct 14, 2020 | 04:33 PM
cacrawley's Avatar
cacrawley
Just wondering if anyone has fitted the wheels from a Mercedes CLA250 to their Mini JCW? I can get a great deal on a set with 205/50r17 which would work good in the pot holed roads around here. The rims are 17" x 7" with ET49 offset, same bolt pattern and center hole as Mini. Wondering what size spacer may be required if someone has tried this before. Thanks in advance for your help.
Corey
Old Oct 14, 2020 | 09:29 PM
Clutch Wotan's Avatar
Clutch Wotan
those you can use
https://www.lochkreisdaten.de/lochkreis/5x112/66.5/
https://www.lochkreisdaten.de/lochkreis/5x112%20/66.6/
Old Oct 15, 2020 | 06:16 AM
cacrawley's Avatar
cacrawley
Thanks for the response. All those on the list will have clearance for the JCW brake calipers without using spacers? Or will spacers be required for all/some?
Corey
Old Oct 15, 2020 | 09:31 AM
Clutch Wotan
You even see the offset more sense pls :-)
muttbear
Tires, Wheels, & Brakes
Aug 19, 2012 11:52 PM
Funsize Clubman
Aug 19, 2012 01:26 AM
Skeeter1
Jul 24, 2009 11:55 PM
revy_ajax
Oct 13, 2008 05:15 AM
spurvis
Dec 1, 2004 08:21 AM
