JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
[help - need advice] Nicks on top of pistons N14
Old Sep 26, 2020 | 06:42 PM
user 58409's Avatar
user 58409
Hi all -
I have an ‘09 JCW with the N14 engine. Long story short, there are 8 bent valves. The guy who replaced the chain and guides reused the single use bolts and didn’t tighten down the cam sprocket enough. There are a couple nicks on each of the pistons (circled in image). Is that a problem? Should they be replaced?
Old Sep 27, 2020 | 09:31 AM
jwzimm's Avatar
jwzimm
Definitely not an expert here but at the absolute very least I would get some scotchbrite pads and "blend" out the raised metal in the top of the piston so it is smooth with the adjacent surfaces. Ridges and high spots like that can create hot spots in the metal which will lead to pre-detonation of the air/fuel charge (aka knock).
Old Sep 27, 2020 | 10:25 AM
oldbrokenwind's Avatar
oldbrokenwind
I used a Dremel grinder on mine, then re-balanced them. 'Course they weren't installed at the time and much easier to do without getting grindings between cylinder wall and piston. As said above --- somehow smooth them out to eliminate hot spots. If not a hi-performance engine, don't worry about re-balancing, just try to remove equal amounts from each piston.
Old Sep 27, 2020 | 10:31 AM
user 58409's Avatar
user 58409
Even though it’s a JCW, it’s a stock N14 engine - so we should be okay with knocking down those high spots?
Old Sep 27, 2020 | 01:14 PM
oldbrokenwind
Yes. By "hi-performance" I'm referring to at least double OEM HP.
Old Sep 27, 2020 | 01:15 PM
user 58409's Avatar
user 58409
He cleaned things up a bit and knocked off the burrs.
SD200
May 6, 2018 01:17 PM
z3ds
Dec 30, 2015 02:41 AM
malibujoey
Factory JCW Talk (2009+)
17
May 1, 2015 06:35 PM
MDL8440
Jul 13, 2010 03:05 PM
