R56 Mini cooper 1.6 overheating in short commutes
Old Aug 26, 2020 | 01:22 PM
Khan Saab's Avatar
Khan Saab
My 1.6 petrol mini 2008 ( psa engine ) is overheating, the coolent boils, and red temprature Icon comes on dash, what all could be possibilities ? Coolent is freshly change also.
i doubt water pump, pump almost 60000 miles old, what all is recommended to change along the water pump ?
Old Aug 26, 2020 | 03:43 PM
GsxR1000's Avatar
GsxR1000
Check electric cooling fan for proper operation. A defective fan could cause engine overheating during short commutes and stop and go traffic.
Old Aug 26, 2020 | 03:46 PM
Khan Saab's Avatar
Khan Saab
Fans are working fine, the thermostat was also changed few days ago, i can see little seepage of coolent under the water pump, but nothing fells on ground .
Old Aug 26, 2020 | 04:51 PM
oldbrokenwind's Avatar
oldbrokenwind
Do a compression test. Leaking head gasket will cause fluid to leak from lotsa different places, while overheating. Also, ensure all air has been bled from the system. Fluid won't flow if it's air-locked at the pump.
Old Aug 27, 2020 | 01:20 AM
Khan Saab's Avatar
Khan Saab
i did compression test a while ago, it was good too.
recently i changed the oil filter housing gasket, but i remember i did not bleed the air out of system, but coolent have boiled two times, the air would have been bleeded or not? And how to bleed air out ?
Old Aug 27, 2020 | 07:44 AM
GsxR1000's Avatar
GsxR1000
To bleed cooling system, you access bleeder screw on top of thermostat housing. Check out following video:
at 31:50, they show bleeder screw. You basically uncrew bleeder screw to let air out. Once coolant starts coming out, tignen screw (Note: it's plastic, just has to be snug).
Old Aug 27, 2020 | 08:11 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Originally Posted by GsxR1000
To bleed cooling system, you access bleeder screw on top of thermostat housing. Check out following video: https://youtu.be/DSe5-CEZALU
OR, use this tool:
https://www.ecstuning.com/b-schwaben...l/003466sch01/
I recently replaced my thermostat, and refilled the system using that tool. Absolutely the BEST tool for filling the coolant system. It is literally as easy as pull vacuum, and fill. Done.
If you have already partially filled the system, you can still use the tool. Pull a vacuum on the system to remove any lingering air, then fill. If the overflow tank gets too much coolant sucked in, just siphon out the excess.
Austinsynthetics
Feb 17, 2016 11:09 PM
ryanleeis
Sep 3, 2012 08:36 PM
mbu
Jan 28, 2012 02:28 PM
shadowwc50
Jun 16, 2011 10:09 PM
