R56 Need Help reading codes
Old Aug 16, 2020 | 04:52 PM
redlinealley's Avatar
redlinealley
First the 3 error lights came up on the dashboard, brake, Triangle and !. Read codes and says ABS/DSC . All wheel speed sensors are working properly. Then 2 weeks later I had a hard time starting the car twice leaving work. At first I thought it was the starter, but I went out to start the car 5x at different times and it started right up. I pulled codes again and have 7 faults.
Old Aug 16, 2020 | 06:52 PM
cpmetz's Avatar
cpmetz
Most of your codes are not present. How is your state of the battery? Battery terminals clean and tight? I'd suggest clearing all codes and start from there.
The only present error is that the rain-light-sensor connection is broken. Maybe a cable is broken, or fuse is gone?
Old Aug 17, 2020 | 03:43 AM
redlinealley
Battery is only 3 months old and terminals are clean and tight. I also have a DME code and steering wheel airbag, DTC does not work, probably because of the other dashboard lights. Which code tells you that the Rain Sensor is not working?
Old Aug 17, 2020 | 05:53 AM
seandallen's Avatar
seandallen
Also:
You can look up the hex codes & their meanings here: https://bmwfault.codes/
Old Aug 17, 2020 | 07:35 AM
redlinealley
Awesome.... I will look them up today.
Mgibrace
Test Forum
Jul 29, 2007 03:10 PM
fms
Test Forum
Jun 4, 2006 09:44 AM
jst4fun
Test Forum
Mar 2, 2006 09:21 AM
jivanivan
Jul 19, 2003 09:40 PM
