FS:: Mini Cooper S JCW GP1292
Old Aug 12, 2020 | 03:34 AM
pglgp1292's Avatar
pglgp1292
Smile Mini Cooper S JCW GP1292
Year: 2006
Model: Hardtop
Price: $18000
Mileage: 76852
Color: Thunder blue
Location (Region): NorthWest
My sweetheart GP1292 is back available for sale!
For those wondering what happened I had originally advertised her here in Dec 2019, and then pulled the advert as it was going to go up on
Bring A trailer. The car had a persistent check engine light and Bring a Trialer rightly rejected the car as it wouldn't pass emissions. In the meantime I relocated to the UK and left the car with my mechanic friend in Portland, OR. So fast forward to today, the check engine light issue (P0172 code) is finaly resolved: Turns out that the car had been tuned with an exhaust leak, when the exhaust leak was fixed the P0172 code got triggered. It sounds realy simple, but it took a huge amount of work to diagnose & fix it, and I'm greatly indebted to my mechanic - So the car since it was last advertised here has had the fuel injectors tested & cleaned, new camshaft sprocket, exhaust and inlet system completely gone through, pressure tested, leak tested, new seals where required. ECU tune reprogrammed by Adrian Nastasecl.
Highlights of the build:
  • RMW Big Valve Head & RMW Street cam
  • RMW Shorty header
  • RMW 440 cc injectors (cleaned & calibrated)
  • Way Motor Works supercharger pulley
  • JRZ RS double adjustable coil over shocks
  • Swift metric coil spings
  • Whiteline end links front & rear
  • H&R adjustable rear anti roll bar
  • Vibra-Technics passenger side engine mount
  • Ported & port matched intaker manifold & inlet plenum
  • RMW teflon intake gasket & ARP studs
  • Colin Green cooling system header tank in black.
  • New OEM TPM & TPMS sensors
  • New OEM fuel pressure regulator
  • New spark plugs
  • New Powerflex front lower control arm bushings & steering rack bushing
  • Cravenspeed oil dipstick & stubby antenna
  • Includes OEM GP car cover
  • Car has been regularly maintained by Mini of Portland (oil changes, brake flush)
Tons of photos below. Ping me with any questions.
Old Aug 14, 2020 | 09:08 AM
Djkf56brg's Avatar
Djkf56brg
Gp
Hi, when you get time please call me, 9, David
Old Aug 14, 2020 | 09:14 AM
pglgp1292's Avatar
pglgp1292
Question
Thanks David, I just called, it rings no answer & there's no voicemail box setup. :-(
Please PM me with an alternative way to contact you, or to chat.
Old Aug 14, 2020 | 09:25 AM
Djkf56brg's Avatar
Djkf56brg
Gp
Hi. I didn’t expect to hear back so soon . My email address is
Old Aug 14, 2020 | 09:26 AM
pglgp1292's Avatar
pglgp1292
Thanks. Yes, I'm a motivated seller! ;-) I'll email you shortly.
Old Aug 19, 2020 | 04:24 AM
pglgp1292's Avatar
pglgp1292
Deposit received. Sale is now Pending.
Thanks everyone for your interest.
biglittle
R55 :: Clubman Talk (2008+)
18
Mar 23, 2021 08:15 AM
Revolution Motor Works
Mar 21, 2020 11:51 PM
dustinhxc
MINI Camera and Video
20
Nov 18, 2012 04:54 PM
Antalyalogy
Sep 19, 2009 07:23 AM
ArmyDog
Asia
Jun 13, 2006 10:51 PM
