Drivetrain air fuel controller
Old Dec 22, 2004 | 08:23 PM
minicoop78's Avatar
minicoop78
air fuel controller
anyone know how to wire it up on the mini i know the turbos are doing it does anyone have i wiring diagram
this would be for the apexi
thanks
Old Dec 26, 2004 | 07:55 PM
minicoop78's Avatar
minicoop78
anyone anyone
Old Dec 27, 2004 | 09:31 AM
MyPocketRocket's Avatar
MyPocketRocket
I want to know more about this as well.
Old Dec 28, 2004 | 12:41 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Safc 1 or 2
Old Dec 28, 2004 | 09:12 AM
TonyB's Avatar
TonyB
If you had not found these discussions, they might be of some help:
https://www.northamericanmotoring.co...t=apexi+wiring
Is that Mugami of MINI2 fame??? If so, welcome to NAM!!! If not, well, still welcome to NAM
Old Dec 28, 2004 | 05:02 PM
minicoop78's Avatar
minicoop78
its the 2
does anyone have the diagram or the color coding that could help?
Old Dec 28, 2004 | 06:09 PM
MiniPilo's Avatar
MiniPilo
From what I have read about the APexi, you need to splice into the T-MAP Sensor and alter that signal so that you can control the signal going to the ECU. Altering this signal, will alter the ammount of air that the ECU thinks is going into the engine, thus effecting the ammount of fuel that it is going to put into the engine.
I have not got one running yet, but plan to work on it. I have a S-AFC version 1 coming, but thinking of changing to the S-AFCII because it has the ability to monitor Knock....
I have the pin-out of the ECU, so I'm going to work on the wiring configuration becuase they both get wired in a similar way. The hard part is the tuning that you will most likely want to do on a dyno for the best results... though I have heard of people doing it on the street. Not the most optimal way...
Old Dec 29, 2004 | 07:49 AM
Mugami's Avatar
Mugami
Yep im the Same Mugami.. thanks for the warm welcome TonyB. BTW yes i do have the SAFC 2 up and running on my MINI.
Hubie from SPI did inform me not to tell anyone of the wiring until after the NOV SEMA show and ive done just that. From the other posting i can see why hes been hesitant. Simply due to the fact. its untested and can cause Major engine damage if done incorrectly. Which wont be covered under any warrenty. I've sent Pilo a PM. If he wants to test it and release the info thats fine with me. I just dont want to be the one they gave the info to someone who installs it. Blows up there MINI (due to mis-programming) then blames me for giving the information.
Until we meet on the road
Have fun, Be safe and Keep MOTOV8N
Old Jan 9, 2005 | 02:20 PM
MiniPilo's Avatar
MiniPilo
The Apexi is intalled, and is working. Will be dyno tuning and testing for a bit before I release a how to. Want to verify every thing before data is released. It was a very involved install, and is not a basic mod
Old Jan 9, 2005 | 02:45 PM
D1JL's Avatar
D1JL
thanks
Buy the Apexi AFC Select p/n 401-X903 this is made for Euro cars and comes with the wiring instructions for the Mini.
Now if I could only figure how th set it.
Dave
Old Jan 9, 2005 | 05:48 PM
minicoop78's Avatar
minicoop78
thanks i already have the other but this is very good to know for the future or anyone else who has interest
Old Jan 9, 2005 | 06:40 PM
MiniPilo's Avatar
MiniPilo
Here is my mounting location!
It is not 100% visable while driving, but it is not meant to be used while driving... so I am fine with this mounting location.. I am just runnig out of space to mount guages, and electronics. It also just fits with my Avic-N1 screen up
Old Jan 10, 2005 | 05:53 AM
D1JL's Avatar
D1JL
I soldered all of my connections, I don't like those crimp things.
Dave
Old Jan 10, 2005 | 06:21 AM
MiniPilo's Avatar
MiniPilo
MAke sure that the brown and black wires are also more then 1cm apart.
Old Jan 10, 2005 | 06:23 AM
MiniPilo's Avatar
MiniPilo
I am just reposting it in a smaller JPG Format
Old Jan 10, 2005 | 07:05 AM
D1JL's Avatar
D1JL
The sensor type is PR-11
Thanks Dan,
I just wasn’t finished yet.
Dave
Old Jan 10, 2005 | 03:33 PM
minicoop78's Avatar
minicoop78
thanks all by the way did you guys just tap in right outside of the ecu housing? and how did you run the wires to keep everything looking nice under the bonnet
mike
Old Jan 10, 2005 | 04:19 PM
MiniPilo's Avatar
MiniPilo
I removed the plastic cover from the connectors, and connected the wires in there. THen I put the covers on, and taped all the wires. I'll get some pictures. and show you.
Old Jan 10, 2005 | 04:22 PM
jlm's Avatar
jlm
how are you going to judge A/F tune?
Old Jan 10, 2005 | 04:23 PM
MiniPilo's Avatar
MiniPilo
Wideband O2 Sensor, on a dyno.
Old Jan 10, 2005 | 04:45 PM
Mugami's Avatar
Mugami
For me im getting the 210 JCW upgrade kit injectors this week with cpu reflash. which will be sent to Franz. Then its off to the Dyno in Feburary for me and final adjustments on High throttle setting using there Wideband O2 sensor equipment. I will adj the low throttle via narrow band O2 and an Autometer or Venom A/F gauge installed.
Old Jan 10, 2005 | 04:58 PM
MiniPilo's Avatar
MiniPilo
I will be using a 420 CC injector that I will be testing. I will be offering these later on.
Dan
Pilo Racing
Old Jan 11, 2005 | 03:12 AM
Mugami's Avatar
Mugami
Oh now you tell me that you may be suppling injectors. I went the way i did because of price. But how you normally break the low price records i might not have gone the best way
Old Jan 11, 2005 | 02:40 PM
MiniPilo's Avatar
MiniPilo
Price may be a bit lower then other, but we have not worked out the final details and price yet. I will keep you informed. but you did get a good deal with what you told me though.
Old Jan 11, 2005 | 04:06 PM
minicoop78's Avatar
minicoop78
how about those pics pilo :smile:
