Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
HPDE Tires
Old Jun 10, 2020 | 04:32 PM
Tom.R56's Avatar
Tom.R56
HPDE Tires
Hi everyone,
I'm planning on running Hankook RS4 on my track set of wheels which are 17x8 +35 I think, I am also running a 10mm spacer all around so I don't rub. Does anyone else run a similar setup? Mainly want to know if a 245/40r17 RS4 would fit on these wheels, I can't find anything solid telling me if they run wide or not.
Old Jun 12, 2020 | 06:00 AM
scotty_r56s's Avatar
scotty_r56s
I'm running Hankook RS4 in 225/45 zr17 on 17x8 Konig Hypergram (ET+45). I needed 15mm spacers in the front and 5mm in the rear. Even with 15mm spacers I was up against the spring perch up front so I had to raise the suspension to clear it. I have about 7mm of space up front. The rear tires are about 10mm the rear training arm. With 2.5 degrees front and 1.5 degrees rear camber, I am just barely rubbing the outside fender liners with a 225. A 245 may require rolling or cutting the metal fender and adding wider flares. I'll know for sure how much it rubs and where the issues are after this weekend. For me, 15mm rears are probably necessary.
Old Dec 9, 2020 | 11:25 PM
Tom.R56's Avatar
Tom.R56
Stumbled upon this and realized I never updated it...
245 RS4 will fit stock body, no trimming of the metal fenders. I raised my car a bit and it clears with a 10mm spacer up front and 5mm rear
Jckol
Jan 31, 2017 07:24 AM
autoXmini
Nov 30, 2009 12:28 AM
BradB
Apr 17, 2008 06:53 PM
acender
SCCA Solo and ProSolo
14
Feb 12, 2008 10:27 PM
BradB
Tires, Wheels, & Brakes
Dec 23, 2006 04:38 AM
