R56 Can you tell which coil will fail?
Old Jun 2, 2020 | 03:55 PM
jlm78's Avatar
jlm78
Hi all,
A couple of years ago, a coil in my 2013 MINI Cooper failed and was replaced. My car is showing the exact same symptoms from a couple of years ago. My suspicion is that another one of the coils is about to go. My question: Is there any way to figure out which ignition coil is about to fail? I know which one was replaced two years ago, so odds are it isn't that one. But I still have three others to pick from. I'm trying to be proactive and replace the one that may be about to fail now before it completely fails. And to this point the car isn't showing any error codes nor is the OBD bluetooth sensor I have showing any problems.
Thanks.
Old Jun 2, 2020 | 05:38 PM
Minifenrir's Avatar
Minifenrir
https://www.waymotorworks.com/direct...9-r60-r61.html
They are only $69 each. I replace all 4 at the same time. But that's just me
Old Jun 2, 2020 | 05:57 PM
AZdsrt's Avatar
AZdsrt
Yep, replace them all so you don't have further hassle down the road..
Old Jun 2, 2020 | 06:14 PM
zrickety's Avatar
zrickety
Facet makes a nice ignition coil, they are made in Italy. Search for Facet 96375, about $25 on Amazon.
Old Jun 3, 2020 | 06:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You may just want to check the spark plugs as it could not even be the coils. We recommend replacing them every 40k.
https://www.waymotorworks.com/spark-...-cooper-s.html
ridinDirty
May 14, 2021 07:15 PM
TimR53
Jan 5, 2018 07:00 PM
TheRedFalcon
Sep 30, 2013 05:13 AM
surya16
Apr 20, 2013 05:42 PM
Silkworm
Apr 18, 2010 07:42 PM
