Navigation & Audio USB pinout on AUX in plug
Old May 31, 2020 | 02:59 PM
AndrewVanis's Avatar
AndrewVanis
2002 R53
Installing this (pic)
https://www.amazon.com/gp/product/B07SSBP183/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07SSBP183/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
It is nice how it goes into the slot in the glove compartment.
The AUX plugs into the stereo fine (haven't tested it yet as the car is going through a rebuild)
I didn't expect to find a receptavcle for the USB port however:
1) is there one?
2) how about wiring into a 12v>5v/USB converter?
Default approach is backtracking the pins using the diagram below and cut the wire. https://www.electroschematics.com/wp...usb-pinout.jpg
The release tabs are on the side. I recommend removing the glove box. It's only a few torx screws. I ended up breaking the tabs to remove. Would have been really hard to remove with glove box installed even if I knew how to remove it already.
Old May 31, 2020 | 06:02 PM
RB-MINI's Avatar
RB-MINI
Correct, 1st gen MINI’s didn’t have USB ports so no place to plug in the green connector.
Adding power from a 5V USB adapter should work, but I would look online for a 2nd gen wiring schematic to see if the green plug is supplied by 12V or 5V, or look inside your adapter to see if a 5V power circuit is already built in.
What is the production date on your radio? Although the radios looked the same throughout the years, 2002 MINI’s didn’t have aux capability without using an aftermarket CD changer input adapter. 9/2002 and later radios should have aux capability. Later radios (around 2005??) added the capability to play burned MP3 CD’s in-dash.
Also, if you look for another radio, the same head unit was used for the standard and Harmon Kardon systems. The HK amp just unlocked other controls and setting when connected.
Old May 31, 2020 | 08:33 PM
AndrewVanis
Originally Posted by RB-MINI
What is the production date on your radio? Although the radios looked the same throughout the years, 2002 MINI’s didn’t have aux capability without using an aftermarket CD changer input adapter. 9/2002 and later radios should have aux capability. Later radios (around 2005??) added the capability to play burned MP3 CD’s in-dash..
My production date is May 02. It did have the CD changer plug plugged in (now replaced with AUX) and it has the Mode button - per amazon seller, if I have Mode button, this should work
...Interesting about there could be a 12v>5v converter in the AUX plug. It would be convenient...How do I test?
Old Jun 1, 2020 | 09:04 AM
Walt's Avatar
Walt
+5v was the older standard. The voltage can now be negotiated all the way up to 20v. Apple (who is notorious for never following other's standard) uses 12v. Samsung Fast Charger likes +9v lately.
Old Jun 2, 2020 | 08:09 AM
chris.j.lamb's Avatar
chris.j.lamb
The USB needs 5V, see here :-
https://www.car-auto-repair.com/bmw-...tion-retrofit/
BazV
Navigation and Audio
Sep 19, 2015 07:16 PM
claytonl
Mar 7, 2012 12:55 AM
vicko5000
Aug 26, 2011 05:30 AM
AkFarina
Mar 10, 2009 02:26 PM
