vacuum pump rebuild kit or replace pump?
Old May 13, 2020 | 11:36 AM
Gabe3's Avatar
Gabe3
came across this on ebay: https://www.ebay.com/itm/RKX-Vacuum-...ZzWOt&LH_BIN=1
my pump is leaking oil. original pump, 95k miles. 07 r56 S. do I replace the pump or do the rebuild kit?
Old May 13, 2020 | 04:15 PM
mildensteve's Avatar
mildensteve
I would rebuild it. Done two of them so far. Works great. Make sure you clean the check valve in the lower brass fitting circuit by blowing cleaner (I used brake cleaner) through it. Otherwise it may stick open and you will suck oil into the reservoir after shutdown. Been there done that. A pain to remove the reservoir, drain the oil, replace the hoses.
Old May 13, 2020 | 06:37 PM
Gabe3's Avatar
Gabe3
I heard these pumps can fail and cause some pretty bad damage to the engine though. so I'm leaning toward replacing.
Old May 13, 2020 | 06:52 PM
mildensteve
Done that too. And I have another brand new one in a box just in case. ECS Tuning had the best price on OEM/Piersburg pumps when I was shopping rather than rebuilding.
ir5m4r7
Mar 1, 2019 11:31 AM
trashmanbob
Jun 17, 2012 02:01 PM
rustyeuro
Cooper (non S)
Aug 29, 2011 11:08 PM
holdenontoit
98
May 10, 2007 08:48 PM
