Suspension H&R complete suspension set up?
Old Apr 24, 2020 | 09:59 PM
E34M5's Avatar
E34M5
Anyone running all H&R suspension? Bought a car with H&R coil overs, installing H&R front 27mm and rear 22mm sway bars. Also installing Power Flex front control arm bushings. Anyone else running this set up? Suggestions on alignment specs for autocross/street, and is it worth installing front and rear strut tower braces, thinking about removing rear seat and making a nice seat delete set up.
Old Apr 25, 2020 | 04:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Do you have camber plates in the front? Do you have adjustable control arms in the rear?
If you are installing PowerFlex bushings in the front, also consider adding the trailing arm bushings in the rear.
https://www.waymotorworks.com/powerf...g-inserts.html
For alignment, I’m running the following numbers on my daily driver Clubman, and the car handles great:
Front
-1.7° camber and 1/32” toe in on each side
Rear
-2° camber and 1/32” toe in on each side
Old Apr 25, 2020 | 08:54 PM
E34M5's Avatar
E34M5
no camber plates, I am going to see what it sits at, would like over 2' camber, has alta rear adjustable trailing arm. I have done alignments on these before and found it easy to get all the adjustment i needed from the rear control arm.
Old Apr 26, 2020 | 04:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I’d be surprised if you could get more than 1.5° in the front without camber plates.
Old Apr 26, 2020 | 08:35 AM
E34M5's Avatar
E34M5
Has anyone just elongated the factory mounting holes on the strut towers to get more camber?
TheClassyMonk
Cooper (non S)
Sep 8, 2016 06:28 PM
minsane
Suspension
Jan 27, 2011 02:40 PM
benzoc
Cooper (non S)
23
Apr 5, 2009 02:30 PM
Z06C5R
Feb 12, 2009 05:00 PM
badassmini
Suspension
Oct 9, 2008 04:05 PM
