R60 Doesn't seem to build very quick.
My wife's car has been running a bit down on.power and trying to track it down. Only reaches 8 psi boost and that is after a long pull and quick gear change and then may hit 8 psi. Just looking where to start looking for issues.
Have you tried looking at the intake piping after the turbo and trough the intercooler up to the throttle body for leaks. The loss in boost could be from loose connections as that piping is only held on by hose clamp like clamps
If you haven't already I'd invest in a OBD2 reader from Amazon, they're cheap and have helped me a lot with my mini. Aside from that I'm not really sure what else it could be, maybe the waste gate on the turbo is faulty? If I remember correctly, it supposed to diver the exhaust fumes so the turbo isn't over spinning.
Daniel Carulli
Sep 30, 2019 08:12 PM
FSP / DSP (Street Prepared) Can you electronically change boost in DSP?
whrisk
SCCA Solo and ProSolo
May 16, 2018 05:07 AM
SooperCuperErik
May 3, 2011 12:58 PM
