Hi all, I'm seriously at a loss and could really use a fresh look on this issue I'm having.
2010 mini clubman s crapped out the water pump and it resulted in blowing the head gasket. Replaced the head and head gasket. Used a 30 over head. Got the vehicle all back together and found out that i had fried the FRM due to unhooking the battery. Had the FRM replaced under the extended warranty.. got the vehicle back and found that the HPFP was crapping out.. took back to the dealership and had it replaced under extended warranty. Got the vehicle back and it now threw the code 2b64 DME: INTAKE MANIFOLD, UNMETERED AIR. I have been researching this code and found that it could be the vanos solenoid or valve cover.
I replaced the vanos solenoid and now the car is throwing a slew of codes!! The codes are in the picture.. any help with this will be greatly appreciated
