R56 Cylinder Head is off what to do "while I'm in there"
Old Feb 10, 2020 | 12:48 PM
2JZ-Sienna's Avatar
2JZ-Sienna
Hi guys, my R56 MCS (N14) has bad valve seals and I need to pull the head on it. What are some things that should be done "while I'm in there"?
I've already got: timing chain job, VANOS solenoid, vacuum pump, thermostat housing, better valve springs, and the head gasket. What else is easily accessible with the head off the engine that I should be taking care of while the heads at the machine shop?
Old Feb 10, 2020 | 01:08 PM
MiniToBe's Avatar
MiniToBe
oil filter housing gaskets, water pipe and front main seal
Old Feb 10, 2020 | 01:15 PM
2JZ-Sienna's Avatar
2JZ-Sienna
Great, adding to my list. More suggestions anyone?
Old Feb 10, 2020 | 05:57 PM
mildensteve's Avatar
mildensteve
Just curious, are you pulling the head because of the valve guide seals or some other reason?
Old Feb 10, 2020 | 07:14 PM
2JZ-Sienna's Avatar
2JZ-Sienna
Yes the valve guide seals. It'll also give me easy access to the combustion chamber so I can clean the carbon off everything while it's off.
Old Feb 11, 2020 | 03:41 AM
mildensteve
You do not have to pull the head just for seals. I just did my '07 MCS valve guide seals along with the timing chain and front main seal. No more blue smoke. No head removal.
cudamank
R60/R61 Stock Problems/Issues
Jul 6, 2019 05:35 PM
GunRuBandits65
Oct 3, 2017 02:09 PM
sarom058
Jul 5, 2017 11:28 AM
nadams93
Jan 2, 2015 05:35 PM
R57Chiller
Cooper (non S)
May 2, 2013 05:08 AM
