R50/53 r53 Pulley Reduction
Old Dec 19, 2019 | 05:57 PM
ninjatuna's Avatar
ninjatuna
I have an 05 r53 with a 17% sc pulley reduction that was installed by previous owner. Has been throwing lean codes for past few weeks and cannot get to the bottom of it.
Are larger injectors such as 380cc necessary with this size pulley reduction? Any other likely causes of lean code?
Old Dec 19, 2019 | 06:32 PM
cooper48's Avatar
cooper48
I run a 15% with stock injectors with no problem. Larger injectors would require a costly tune because your ECU has to be adjusted for a differing injector duty cycle. Have you tried injector cleaner in the gas tank?
Old Dec 19, 2019 | 06:38 PM
Black Forest's Avatar
Black Forest
Lean codes could also arise from a vacuum leak.
Old Dec 19, 2019 | 08:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You don't need bigger injectors. Need to diagnose the fault. It could be many thinks as simple as a vacuum leak, exh leak, bad sensor and so on.
Old Dec 19, 2019 | 09:04 PM
BlwnAway's Avatar
BlwnAway
Ditto, undersized injectors will not just all of a sudden start throwing a lean code, if anything it would have always been there if that were the case.
And yes, vacuum leaks should be the first thing to look at, our fuel regulators are controlled by vacuum, incorrect vacuum/boost, incorrect fuel delivery to the injectors.
And yes, the ECU does such a good job of controlling things, it doesn't take much to hide a vacuum leak so that it's not really noticeable with the normal rough idle signs.
ninjatuna
Dec 9, 2019 06:00 PM
Josue.Rodz
Apr 29, 2011 07:28 AM
DarkMiniCooperS
Jan 17, 2007 05:43 PM
resipsamcs
Feb 15, 2006 07:11 PM
hamann_s
Nov 8, 2005 01:29 PM
