Suspension Replace Self-Tapping/Tri-lobe Bolts
Old Nov 25, 2019 | 09:16 AM
blackR53's Avatar
blackR53
What are peoples thoughts on replacing a self-tapping/tri-lobe bolt (like rear lower shock bolt) with a regularly threaded bolt of same size and grade?
Would the thread contact be the same?
Old Nov 26, 2019 | 10:48 PM
Mini_Crazy's Avatar
Mini_Crazy
FYI: The R56 lower shock bolts are "regular" bolts (not tri-lobe), and the shoulder is the right length, which is challenging if you try your local Fastenal fastener store. Thread length is a bit longer, but they can be trimmed.
Untrimmed will be perfect if you decide to switch to the aluminum R56 trailing arms too.
Old Nov 27, 2019 | 04:05 AM
blackR53's Avatar
blackR53
On the Aluminum trailing arms I just swapped on to my R53, they came with tri-lobe lower shock bolts. Maybe there are differences in the years, I’m not sure what car they came off of.
Ah, yes, I didn’t think about the shoulder for that bolt though. I wasn’t going to worry too much about length since it is open on the back.
I’d really like to replace the top shock mount bolts but not sure on the thread situation.
avinrulez
Sep 9, 2018 05:02 PM
s29_myk
24
Jun 18, 2016 08:01 PM
micromini234
Dec 31, 2014 06:04 AM
marantz2010
May 28, 2014 09:44 PM
tummi_gummi
Apr 14, 2014 05:39 AM
