Drivetrain What sort of IAT are you seeing?
Old Nov 16, 2019 | 08:54 AM
ditc's Avatar
ditc
Reviewed some data from past track days and on a 80degree ambient day, after a few laps I am seeing IAT’s peak at 140 degrees. I thought that is a bit high since I have a Helix FMIC, but then I am on track with RPM stage 2. Could there be some obstruction, FMIC not ‘working’ ? Most of the time IATs that day were 110-120 degrees. Curious what others were seeing and under what conditions.
Old Nov 20, 2019 | 05:44 PM
cyberlunacy's Avatar
cyberlunacy
if you have a CIA then all your hot engine bay/turbo heat is getting sucked into the air intake.
maybe i am wrong but seems pretty hot.
someone should make a hood with an upper hood scoop like suburu so that are is pulled directly into the CIA
Rosie077
Jul 20, 2013 04:51 PM
MattyKHZ
Apr 4, 2013 02:12 AM
DoubleNick
Jul 23, 2011 08:42 AM
5zero4
Mar 26, 2011 05:03 AM
royce
Dec 29, 2006 07:39 PM
