R50/53 Bargain $500 Mini-Power steering
Old Nov 15, 2019 | 06:06 AM
robj's Avatar
robj
Jumped back here from my build thread for a quick question. As the subframe was out for LCA bushings, I removed the rack and pinion to clean it up and replace the hoses. I drained the oil from the tank and the hoses but most of the oil probably remained in the rack. I didn't remove the high pressure lines.
After re-installing, can I just fill the reservoir and turn the wheel back and forth or is bleeding from somewhere involved?
Thanks,
rob
Old Nov 15, 2019 | 06:01 PM
Racingguy04's Avatar
Racingguy04
yup, just fill the reservoir, and turn the wheel from lock to lock a few times, keeping an eye on the fluid level. It's best to do it with the wheels in the air.
Old Nov 15, 2019 | 07:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes just refill it and turn back and fork several time then when you start the car do it some more until it bleeds out all the air.
Nburd
Oct 25, 2018 04:00 PM
chrisdurand
Jun 4, 2017 02:52 PM
SooperSara
May 31, 2012 10:01 AM
IQRaceworks
Mar 26, 2012 07:26 AM
jrprich
Jan 14, 2010 11:11 AM
