R55 Engine swap or head swap
Old Nov 6, 2019 | 04:40 AM
FrankBlack's Avatar
FrankBlack
Now that my Mini is kaput, I was thinking or either an engine swap or head swap. Any idea what's compatible? Is there a spreadsheet somewhere with this info? or should I just part it out. It's got a lot of really good parts.
2009 R55 Clubman S
Thanks,
Frank
Old Nov 6, 2019 | 06:46 PM
Rob Rocheleau's Avatar
Rob Rocheleau
Not sure if this reply will be what you are looking for regarding a spreadsheet. The link below lists the engines and chassis combinations.
Best of luck with your quest. A re-man head seems to be around a thousand dollars on a famous auction site, and a re-man long block goes for around $4,500. Used engines from LKQ are running pretty close to the price of the re-manufactured one. There are some cars locally around Rhode Island on Craigslist, for about the same money or less as the engine options, if you want to buy a running car and poach the engine for yours.
https://www.motoringalliance.com/art...gine-codes.46/
The following are the engine codes for all current MINI Cooper’s (Not Classics)
First Generation MINIs
2002-2006 R50 Cooper = W10 (W10B16) 1.6 Non Supercharged
2002-2006 R53 Cooper S = W11 (W11B16) 1.6 Supercharged
NOTE: 1st gen convertibles were made at the same time the 2nd gen Coupe was. Lots of people get confused when they have a 2007 or 2008 convertible and think its a 2nd gen.
2005-2008 R52 Cooper Convertible = W10 (W10B16) 1.6 Non Supercharged
2005-2008 R52 Cooper S Convertible = W11 (W11B16) 1.6 Supercharged
Second generation MINIs
NOTE: 2nd gen Convertible was released in 2009 in Cooper and Cooper S trim.
2007-2010 R56 and R57 Cooper = N12 (N12B16) Non Turbo
2007-2010 R56S and R57S Cooper S = N14 (N14B16) Turbo
2008-2010 R55 Clubman = N12 (N12B16) Non Turbo
2008-2010 R55S Clubman S = N14 (N14B16) Turbo
Engine change for 2011
2011 + R56 and R57 Cooper = N16 (N16B16) Non Turbo
2011 + R56S and R57S Cooper S = N18 (N18B16) Turbo
2011 + R55 Clubman = N16 (N16B16) Non Turbo
2011 + R55S Clubman S = N18 (N18B16) Turbo
2011 + R60 Countryman = N16 (N16B16) Non Turbo
2011 + R60S Countryman S = N18 (N18B16) Turbo
2011 + R60S Countryman S ALL4 = N18 (N18B16) Turbo
Source – Post by Professor on the Bluegrass MINIs site
Third Generation MINIs
The engines now have a B code and are modular in design. B37 and B38 are 3 cylinder, B48 is 4 cylinder.
2014 Cooper – B38A15A (1.5L 3-cylinder) – 134HP
2014 Cooper S – B48A20A (2.0L 4-cylinder) – 187HP
JCW - B48A20B - (2.0L 4-cylinder)
Cooper D – B37 – 114HP
Old Nov 7, 2019 | 04:17 AM
FrankBlack's Avatar
FrankBlack
Thank you so much!! This definitely helps!!
Old Nov 7, 2019 | 10:06 AM
Rob Rocheleau
You are welcome. Keep us posted with your progress, if you can.
Old Nov 12, 2019 | 10:43 AM
cbracerx's Avatar
cbracerx
If you are handy, rebuilt head and a new timing chain seems the way to go, unless you had so many miles on the car that the short block might be getting worn. If you aren’t handy then an independent shop installing the head might be less expensive than the dealer.
Old Dec 5, 2019 | 05:38 AM
MiniToBe's Avatar
MiniToBe
2009 R55 Clubman S
Thanks,
Frank
If it is only a burnt valve and not cylinder wall damage, then the repair cost is a lot cheaper. 5 years ago, I never would've thought I would be a "mini whisperer" today. This site and other few resources were the stepping stone to master 2nd gen minis. Anyway, cost wise, you're looking at less than 500 for parts ({aftermarket}1 ex valve, head gasket, stem seals, head bolts, timing chain and bolts, turbo oil feed line, oil filter housing gasket and a front main seal). I know as in most cases, labor cost tips the scale.
Old Dec 5, 2019 | 07:02 AM
FrankBlack's Avatar
FrankBlack
Thanks cbracerx and MiniToBe, The mileage is 135K. If I could do the job I would do it, this type of job is out of my skill set. It's killing me too because I have repaired the water pump, the thermostat, changed the struts, shocks, sway bar, intercooler etc... so I have no fear about ripping apart the Mini to fix it, I don't have the knowledge or correct tools for the timing chain to accomplish this type of repair.
Old Dec 5, 2019 | 07:19 AM
MiniToBe's Avatar
MiniToBe
Review newtis.info for the how to. You need basic torque wrenchs and the timing tool isn't expensive to acquire. We're here to help and could walk you through the process if you go that route. If the car isn't your daily driver, then you could take your time on it.
JD Wagner
Cooper (non S)
83
Feb 22, 2023 03:42 PM
Dec 16, 2015 03:02 PM
cadfael_tex
Oct 10, 2015 06:40 AM
Peep
Jan 10, 2013 03:34 PM
Moreno Chulo89
Jun 17, 2012 06:05 AM
