R55 Cylinder 3 misfire and flashing CEL
Old Oct 18, 2019 | 05:29 AM
FrankBlack's Avatar
FrankBlack
2009 Clubman S 135,000 miles. Cruising down the highway at 80mph and it starts hesitating. I scan it with my phone app and it says cylinder 1 misfire. The CEL is flashing. Then all hell breaks loose. All cylinders are misfiring. I get home and change out all the plugs and coils. (saved from the pervious swap in Jan 2019) Start it up and my Swaben says cylinder 3 misfire. High pressure fuel pump shut off. I reset all the codes. Install new plugs and coils. Again cylinder 3 misfire.
Questions: What are some of the causes for the same cylinder to misfire? Is there something common at this mileage?
Any ideas, comments, greatly appreciated
Thanks Frank
Old Oct 22, 2019 | 03:16 AM
FrankBlack's Avatar
FrankBlack
Got this code 2B64 unmetered air. Things I have checked so far. Timing chain and guides, Vanos, PCV, all look ok. Looked inside the cylinders as best I could with a flashlight. Couple of cylinders looked like it could be wet on the top. Hard to say. Cylinder 1 looked like there was some black gunk on top. Like I said hard to tell and I have nothing to compare it too because I've never had an issue like this.
Old Nov 4, 2019 | 04:41 AM
FrankBlack's Avatar
FrankBlack
Bump
Old Nov 4, 2019 | 12:57 PM
RockC's Avatar
RockC
The misfire with #3 cylinder may be self inflicted. I note the misfire moved from #1 to #3 after you replaced the plugs and coils.
This suggests that something is amiss -- no pun... -- with the connection of the coil to the plug or with the coil to the engine wiring harness. The coil must be properly secure so it has a very good ground.
I'd suggest you double check your coil/plug work.
If you find nothing to account for the #3 cylinder misfire you probably want to focus on the unmetered air issue.
The intake system is a pretty complex air flow device and anything out of the ordinary could account for a cylinder misfiring. The other cylinders may be close to registering a misfire it is just the #3 cylinder gets over the threshold first.
No direct experience but with two people I know who both had cars that generated a persistent misfire one was caused by an over rev of the engine -- apparently there was no rev limiter to protect the engine and a valve floated and touched a piston and was bent.
In the case of the other car at something over 100K miles an exhaust valve burned. This was a turbo charged engine (Subie car) and exhaust valves can run pretty hot.
In both of these cases were one applicable to your engine a compression test would likely find a low cylinder pressure in the #3 cylinder. If adjacent cylinders are low that could be a head gasket leak between cylinders.
While I've never encountered a bad injector techs have told me a lazy injector can cause misfires. I have never had to touch injectors and I'm very reluctant to mess with these unless it is clearly necessary and am just as reluctant to send you on an injector R&R but if you find no other reason to account for the misfire behavior...
Old Nov 5, 2019 | 03:59 AM
FrankBlack's Avatar
FrankBlack
Thanks for your response. I had it towed to the dealer. It starts and runs, just not very well. I'll report back with the diagnosis. Hopefully I won't get clobbered!
Old Nov 5, 2019 | 10:22 AM
FrankBlack's Avatar
FrankBlack
James Michael
Oct 17, 2019 11:49 AM
spatulatr0n
R55 :: Clubman Talk (2008+)
Mar 17, 2017 01:21 PM
samtruongg
Aug 27, 2013 06:29 AM
Streakerr
Jul 16, 2013 08:51 AM
nethack
28
Apr 26, 2013 01:52 PM
