R52 Code P0036, replaced O2 sensor, came right back!
Old Oct 7, 2019 | 06:45 AM
rauls4's Avatar
rauls4
Any ideas? I did use an inexpensive O2 sensor. Should I just bite the bullet and get OEM? Could it be something else?
Old Oct 8, 2019 | 02:54 PM
RockC's Avatar
RockC
Did you replace the right sensor? My info is the code refers to the sensor *after* the converter.
Did you clear the code after you replaced the sensor? The code won't clear itself until the engine has gone through several warm up cycles.
P0036 refers to a heater circuit problem. Assuming you replaced the right sensor and the replacement sensor is acceptable -- always a bit of a gamble: I' have always subscribed to using OE senors when replacing O2 sensors -- there could be a sensor connector problem at the wiring harness or a wiring problem or even -- very rare -- a problem with the engine controller.
Here's a link to something you might find of value:
https://www.obd-codes.com/p0036
Old Oct 8, 2019 | 04:50 PM
rauls4's Avatar
rauls4
Yes, I did replace the sensor behind the cat.
I cleared it using a Schawen OBDII tool. Started the car, no code. But as soon as I turn it off and restart, it comes back on. I drove it on the highway to bring it to full temp. Same results.
I did place an order for an NTK sensor from ECS (I read that Bosh might be problematic, but mostly on forward sensor. Still, just in case).
I am going to replace it this weekend (along w (unrelated) compressor, accessory belt, dryer and power steering fan). Hopefully that takes care of the problem.
Thanks for your help.
Old Oct 8, 2019 | 07:15 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We see issues with Bosch and other aftermarket 02 sensors all the time so I would get an OEM or NTK. We keep both in stock
https://www.waymotorworks.com/ngk-o2-oxygen-sensor.html
Old Oct 16, 2019 | 02:53 PM
rauls4's Avatar
rauls4
NTK Sensor did the trick. Wasted $24 on the cheap Chinese POS sensor.
J Free
Jun 1, 2017 08:06 AM
alexs3d2
Sep 6, 2014 09:59 AM
tiny s
Jun 6, 2012 01:17 PM
jrprich
Sep 6, 2008 06:46 PM
Kendel72
Sep 1, 2006 07:57 AM
