Power steering wiring question
Old Oct 5, 2019 | 06:12 PM
xenocide's Avatar
xenocide
I'm putting an R53 back together 1.5 years after I took it apart. I can't find where the "lug" wire (the one with a hole in it meant to go over a bolt) of the large wire pink/orange wire from the Power Steering pump goes. The red wire with the white plastic clip goes underneath the fuse block and the other one must connect somewhere close as it's in the same sheath but I'm not seeing it. Help!
Old Oct 5, 2019 | 06:25 PM
xenocide's Avatar
xenocide
Where does the wire I’m holding go? This is below the fuse block in an MCS.
Old Oct 6, 2019 | 05:01 AM
xenocide's Avatar
xenocide
I'm going to assume this wire is "brown" and is the ground per the diagram and goes on the stud under the power wire in my picture.
blalor
Apr 14, 2015 05:08 AM
minibuddy
16
Dec 27, 2012 08:26 PM
lefty03
Jan 15, 2012 02:52 PM
JenW
Feb 10, 2006 05:41 AM
