R55 Sub-woofer
Old Sep 26, 2019 | 06:57 AM
RainfallSerenade's Avatar
RainfallSerenade
R55 Sub-woofer
Hey guys, I looked around and couldn't find definitive answers so, I'll ask here. My R55 has a stock audio setup and I really wanna get a bit more bass out of it. Is it possible/easy to install a woofer using the stock stereo? I saw threads for doing it with the hifi system but, couldn't find anything for the base audio system.
Any recommended cheap, thin woofers and ideas where to mount them would be greatly appreciated too!
Thanks all!
Old Sep 26, 2019 | 07:39 AM
Scudder44's Avatar
Scudder44
This is what I have and fits under the passenger seat and wired to the speaker wires (hi level input) in the footwell. In Phase Car Audio USW10 300W.
Old Sep 26, 2019 | 01:14 PM
grunte's Avatar
grunte
@Scudder44 What make and model did you get? I've been looking for one to fit under the passenger seat of my R55 and can't.
TIA
Old Sep 26, 2019 | 01:18 PM
Scudder44's Avatar
Scudder44
Erm In Phase, as above.
Old Sep 27, 2019 | 07:44 AM
RainfallSerenade
How do you wire something like that in to the stock stereo? That's the biggest concern I have is the how. *fairly amateur with that sort of stuff*
Old Sep 28, 2019 | 12:10 AM
Scudder44's Avatar
Scudder44
FR = front right
FL = front left
RR - rear right
RL = rear left
TTHL- BL/SW RL-
MTVR+ GE/BR FR+
MTVR- GE/SW FR-
MTVL+ SW/RT FL+
MTVL- SW/VI FL-
TTHR+ BR/OR RR+
TTHR- GE/RT RR-
TTHL+ BL/BR RL+
Colors:
SW black
BR brown
RT red
OR orange
GE yellow
VI violet
BL blue
In the footwell, behind the pannel there is a connector block with all the speaker cables. I took the tap off after the connector. It is tight in there but if you remove the inner plastic sill cover carefully (held on with plastic clips) it gives more access. I tapped into the rear speakers. 4 connections - RR+ RR- RL+ RL- . All the cables came with the In Phase speaker and I used push fit tap connectors.
Last edited by Scudder44; Sep 28, 2019 at 12:14 AM. Reason: removed some irrelevant info
MotorWorf
R55 :: Clubman Talk (2008+)
Feb 28, 2025 09:45 AM
mark225
Jul 14, 2019 02:52 PM
jack1383
Apr 10, 2018 07:00 AM
kingbc
Nov 23, 2015 11:27 AM
conger
Aug 15, 2013 05:13 PM
