R50/53 Suggests for fix action... Coolant in oil
Old Sep 3, 2019 | 03:00 PM
JCW_CBLACK's Avatar
JCW_CBLACK
I attempted to post this two days ago but something failed.
i was overheating and got and stayed hot, I found a cracked expansion tank and replaced it. Before I found the coolant in the oil I was starting to use fluid on short trips and thought it was from the crack in the tank.
So I replaced and still have pressure on the coolant after a night to cool,. I may going to replace the thermostat but looking for suggestions while I have the car apart to look for.
Will look at the oil cooler as possible point that the leak is..
Other other suggestions would be great.
Old Sep 3, 2019 | 03:22 PM
veedubpat's Avatar
veedubpat
Head gasket if you've overheated the block.
Old Sep 5, 2019 | 10:23 AM
IQRaceworks's Avatar
IQRaceworks
There is a seal on the oil cooler that separates the oil...from the coolant. That seal can go bad and let the two mix. Maybe check that first?
Old Sep 5, 2019 | 10:29 AM
JCW_CBLACK's Avatar
JCW_CBLACK
I have a new thermostat, oil cooler and seals on order...that was the plan. thanks.
Racingguy04
Jan 16, 2019 10:08 AM
idickers
Aug 7, 2014 11:00 AM
MisterClean
Dec 20, 2011 07:15 AM
pogipaul
Mar 8, 2010 09:16 PM
