JCW BorgWarner turbo part numbers?
Old Aug 14, 2019 | 12:35 AM
Burt99's Avatar
Burt99
JCW 2011 N14 97,000miles (UK)
So I’m repairing a leak at the oil filter gasket and have completely stripped the front down. Whilst I have easy access I’m doing preventative maintenance/mods:
oil feed/return pipes
filter housing (both sets of gaskets)
200cell downpipe
thermostat
Now the turbo has always been noisy, and I’m planning on rebuilding it, as I’ve done a K03 before and it was relatively easy. After popping the intake hose, the compressor wheel blades have loads of small chips, so a new wheel is needed too. The inner sleeve where the air intake connects to the flange has chunks missing,so I’m assuming the culprit...well done Mini
Does anyone know the BorgWarner rebuild kit number for the N14 JCW, I believe it’s a K03 2080? Also the product code for the wheel, which I assume is a 51mm?
Lastly... can anyone recommend any simple turbo mods whilst I am there eg larger wheel/housing, or is it not worth bothering.
Thanks guys
oldbrokenwind
Mini/MINI BUILDS
Sep 27, 2019 11:46 AM
chav
Apr 22, 2017 08:12 AM
Dr. Spade
Jan 29, 2017 12:49 PM
chav
Mar 16, 2016 03:00 PM
Hank Rearden
Jul 28, 2013 09:04 AM
