Mini Cooper S rough idle, P115C: carbon deposits? Harness?
Old Jul 23, 2019 | 01:12 AM
cpmetz's Avatar
cpmetz
Hi all,
Recently got an interchange yellow convertible an now in the process on getting it roadworthy.
Issues were a CEL right when I drove off the parking lot where I bought the car (oh boy). Code is 115c. Car has a new MAF (thanks again, seller... you could have told me...).
Today I removed the throttle body to clean )somewhat dirty and found the harness damaged (close to the intake, was rubbing against it).
I looked at the diagram and it looks like a sensor wire.
Had to take the intake off because I couldn't get the cleaned throttle body back on, and while in there looked at the valves.
How bad is this? Could that also be a reason for a P115C?
Anyone with a mobile walnut blaster setup in the SF Bay area that I can throw money at?
Old Jul 23, 2019 | 05:12 AM
knt's Avatar
knt
It does look quite carboned up, not sure if the code has any bearing on this.
Done a quick search and people with the same codes reference it tp throttle body.
ragingMINI
Oct 26, 2020 12:52 PM
fixthedoor
R55 :: Clubman Talk (2008+)
Sep 14, 2016 07:03 AM
djenks76
Jun 10, 2016 10:18 AM
Nj05mcs
Nov 5, 2011 03:30 PM
countryboyshane
Aug 4, 2009 03:19 PM
