R59 Intermittent A/C: fan, resistor, or ???
Old Jul 13, 2019 | 06:21 PM
Jim Ekrut's Avatar
Jim Ekrut
A/C blows cold for a while, then stops unexpectedly. May stay off short or long time. Longest running use before failure is two days.
Have replaced thermostat (trouble code) as advised by dealer. Also replaced cooling fan. System evacuated and recharged recently, shows full charge and appropriate pressures when it's running.
Haven't officially found A/C relay under hood, only fan icon. Is there another A/C relay and, if so, where do I find it? I want to confirm whether the A/C clutch coil is within normal resistance range.
If there's a cooling fan controller resistor, I'd love to know its location, too.
Thanks for helping!
Jim E., Fort Worth, TX
Old Jul 15, 2019 | 06:56 AM
I would scan it with the schwaben tool to see the fault first. Might be a flap shutting down or something else.
https://www.northamericanmotoring.co...d-q-and-a.html
Old Aug 2, 2020 | 06:00 PM
Jim Ekrut's Avatar
Jim Ekrut
Thanks for helping!
Update: a/c issue resolved for some months by finding and repairing faulty electrical connections from unknown previous service. Intermittent a/c has returned, but very random: can happen when car is hot or cold, but seems better at highway speeds.Wondering whether perhaps the coil is weak and fails some at low speeds but has ample voltage when faster. Hard to confirm a definite pattern. No codes showing. Is there a resistance test for the clutch coil?
Old Aug 7, 2020 | 05:14 PM
TG.'s Avatar
TG.
So is it fixed or intermittent?
Old Aug 8, 2020 | 04:30 AM
Jim Ekrut's Avatar
Jim Ekrut
still intermittent. one short trip yesterday, worked entire time; the day prior, off and on for most of a ten minute errand. sometimes seems to work more consistently on a longer highway speeds trip
Old Aug 8, 2020 | 11:00 AM
TG.'s Avatar
TG.
From what I've heard on AC in general is that sometime the compressor clutch gets worn out and the compressor doesn't engaged anymore which result in no AC. It's ones of those slow aging things that makes it work at times and not other. I have similar issu on an other car but haven't had the chance to take appart the compressor pulley to check things out.
This might help:
I don't know how similar it is on a mini...
Old Aug 8, 2020 | 12:08 PM
Jim Ekrut's Avatar
Jim Ekrut
Thanks! I've heard that's a known issue. The air blows really cold when it's working, so I don't want to spend a small fortune on the whole system. When an independent mechanic found wiring issues that the dealer missed, we thought the issue was resolved, but you may be exactly right. It's hard to catch it not working to test voltages at the A/C coil/clutch, which is pretty inexpensive and not impossible to replace DIY. Here's a video I found: it's for an older model, but looks almost identical. This is a base engine, so no turbo plumbing to deal with.
Old Aug 8, 2020 | 03:58 PM
TG.'s Avatar
TG.
Great how-to as well! I like how it gives a hint as what do do on a mini...
rrv2112
Apr 19, 2017 05:25 AM
50shadesofr53
Aug 23, 2016 05:20 PM
BoostCzaR53
Jul 9, 2012 11:38 PM
raypistonbroke
Nov 11, 2011 08:45 AM
Cali44redrocket
Dec 21, 2008 11:43 AM
