Navigation & Audio amp for front stage 2012 mcs with h/k
Old Jun 18, 2019 | 12:42 PM
scott freedman's Avatar
scott freedman
Hello all I am in the process of building out the stereo in my mini (new to me) it's a 2012 with the HK
Step 1 change the amp
I know i want a different amp. I just purchased a JL 300/4 perfect for 4 ohm OR 2 ohm speakers 75x4 into 4 or 2 ohms .(good for now and good for later)
use a x9331 and get the "front" signal to the amp. (do i really need this? I could pick it up at the amp the JL will take a high level input I might only need the + part of the input. Seems like a waste of 100 bucks just to pick up the signal
use the amp in 4 channel mode with the stock speakers. cross the 5.25 over LP at about 300 - 500,
is there any type of passive crossover on the mid / tweet
question does anyone know which wires to pick up at the amp.
I did this in my 1994 bmw 325is. it also had 3 way up front. 4/1 in the door and a 6 in the kick. its only 12 wires
Step 2 replace the speakers with some better speakers that I have in my garage (focal 2 way or 3 way or something similar to be acquired)
Step 3 head unit (this looks like a pain in the neck but it's the only way to get android auto)
Step 4 add a sub if needed
https://www.northamericanmotoring.co...am-needed.html
Left Mid/Tweet - blue/brown stripe & blue/black stripe
Left Woofer - Yellow/brown stripe & Yellow/black stripe
Right Mid/Tweet - blue/white stripe & blue/brown stripe
Right Woofer - Black/purple stripe & black/red stripe
This contradicts https://www.northamericanmotoring.co...r-diagram.html
Power Input
(Pin - Wire Color - Function)
5 - Red/Gray (This is a 20A circuit that should provide power to a modest aftermarket amp without needing to run a seperate lead)
10 - Power Antenna lead (to turn on your aftermarket amp. I'll check the voltage/operation when I can).
26 - Brown (Ground)
18 - Orange/Green (No idea, but it causes me concern as it's labeled "K_CAN_L")
19 - Green (No idea, but also causes me concern as it's labeled "K_CAN_H")
Audio Input (Speaker level input from headunit)
(Pin - WireColor - Polarity)
Front Left
38 - Black/Red (+)
30 - Black/Purple (-)
Front Right
9 - Yellow/Brown (+)
17 - Yellow/Black (-)
Rear Left
37 - Blue/Brown (+)
29 - Blue/Black (-)
Rear Right
8 - Brown/Orange (+)
16 - Yellow/Red (-)
Output (Speakers)
Front Left Woofer
41 - Black/Red (+)
42 - Black/Purple (-)
Front Right Woofer
39 - Yellow/Purple (+)
40 - Yellow/Gray (-)
Front Left Mid/Tweet*
33 - Blue/White (+)
34 - Blue/Brown (-)
Front Right Mid/Tweet*
11 - Blue/Black (+)
12 - Blue/Brown (-)
Rear Left Woofer (6x9)
4 - Red/White (+)
3 - Brown (-)
Rear Right Woofer (6x9)
23 - Red/White (+)
22 - Brown/White (-)
Rear Left Tweeter*
31 - Yellow/Black (+)
32 - Yellow/Brown (-)
Rear Right Tweeter*
13 - Yellow (+)
21 - Brown (-)
some tags. to help people in the future search
r56 stereo amplifier harman kardon hk h/k wire diagram pin out mini cooper
Old Jun 18, 2019 | 02:20 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
For wiring help look at newtis.info . Apparently MINI/BMW often changes up the color combos so really the best way is testing the wires. I've only upgraded a third gen MINI so not much help on second gen.
Old Jun 18, 2019 | 05:31 PM
scott freedman
That's perfect. I'll post my results here later. But I found the right page
Old Jun 18, 2019 | 06:41 PM
scott freedman
the colors i posted above seem to match the colors and labels (ish) in the diagram https://www.newtis.info/tisv2/a/en/r...ier/1VncKukH8c. at least enough to isolate and do a decent test.
badinfluence
Apr 7, 2011 07:20 PM
guitfiddler
Oct 10, 2007 12:04 PM
