WARM idle issue on n18 mcs
Old Jun 5, 2019 | 10:38 AM
Squigglesr56's Avatar
Squigglesr56
I kno there are a lot of cold start idle issue noted on here but i havent seen many on idle issues when warm. And most i have found are for the n14 not the n18. So heres the issue id say 90% of the time when i start my mini it will start fine the idle will go up like normal and after bout 10 seconds it drops to about 400 - 500 never stall tho. Itll dip that low for 1 or 2 seconds and then goes to about normal rpm. But does not idle smooth it will jump up and down a very lil. Also you can feel a lil stumble after u get on it on low rpms. Im gona put in new plugs today after work to see if it helps. Im not sure if it will tho because it only does this when warm. Never 1st thing in the morning. Ive replaced pretty much all major fuel system components by a shop within the last month including lpfp, fuel filter/ whole sending unit, hpfp . I dont remember this happening as often before the work. I think it would once a month or so. Id like to track down the issue myself or try before i bring it to the shop again.
Old Jun 6, 2019 | 11:47 AM
holkki's Avatar
holkki
Bad Vanos solenoid, try first clean it . If does not help, then replace it.
Old Jun 7, 2019 | 04:49 AM
Squigglesr56
Originally Posted by holkki
bad vanos solenoid, try first clean it . If does not help, then replace it.
thank you io will try this weekend. Also gona try to clean the maf sensor to.
Old Jun 10, 2019 | 05:10 AM
Squigglesr56
This weekend i put in new 1422 plugs gapped to .22 or whatever the spec was cant remember exatly now, cleaned the front vanos and maf sensor. Now when i start it the drop in idle isnt so big as before but its still there. I didnt remove the intake vanos because i got lazy but i may this weekend and try leaning it to..mabey ill get luky and it will fix it. How can you test the vanos to see if they are good? Id hate to just throw parts at something.
lissascheuerman
Feb 20, 2013 08:49 PM
Sperry50
22
Jan 14, 2012 05:37 PM
xxxpete
Aug 7, 2011 07:09 PM
rimtnbiker
Jun 2, 2011 02:49 PM
crbowers
Mar 3, 2004 02:40 PM
