R52 Convertible top hydraulic pump valve
Old May 19, 2019 | 12:17 AM
Jordan Rodriguez's Avatar
Jordan Rodriguez
Hi! I’m in the final stages of repairing the top (replaced rear quarter panel window regulator and left latch) and have a question about the ****-off valve for the pump. I jumped the gun and unscrewed it without counting 1.5 turns. Is the screw supposed to be fully tightened?
TIA!
Old May 19, 2019 | 12:29 PM
A383Wing's Avatar
A383Wing
be careful, I stripped mine by tightening it too much.....should be screwed all the way in by turning it to the right.....just be careful and do not use much force
Bryan
Old May 25, 2019 | 04:45 AM
gum's Avatar
gum
I did replaced both quarter window motor on mines and it didn’t make any difference buttering with that release screw, the convertible it goes down slowly. as the same as if I didn’t unscrew it 1.5 times.
Old May 25, 2019 | 09:56 AM
A383Wing's Avatar
A383Wing
From my understanding, you unscrew the little hex screw 1.5 times if you have an issue with your top not working and you have to put it up manually with a helper. The opening of the screw provides the fluid to transfer to the other reservoir in the pump slowly wnem moving the top into position without the top motor running
Bryan
Mar 20, 2018 08:08 AM
MassMini
Apr 21, 2017 02:08 PM
PelicanParts.com
Apr 20, 2017 09:32 AM
Gestur
European MINIs
Jul 12, 2009 08:40 PM
DustinDallas
65
Mar 20, 2005 07:14 PM
