R60 Base suspension springs VS Sport
Old Feb 13, 2019 | 01:10 PM
RCRacer's Avatar
RCRacer
I've been reading a lot of the threads and searching a lot of websites, but I can't find a clear answer.
Our 2013 Countryman with standard suspension is in need of at least new rear struts because it's pretty bouncy and makes the handling over-reactive.
I would love to go with the Bilstein B6 HD, but this is the 4th family car so I have to keep cost under control. I found the Bilstein B4 replacements for the Sport and JCW suspension which are very affordable where I could justify replacing fronts too, BUT do I need to go to a stiffer spring as well, or are the springs the same for sport vs non-sport? I can't find any info on springs, not even on realoem.com.
The next option would be something like Eibach springs, or some other aftermarket spring but I would rather not spend the money if I don't have to.
The other thing I am considering is getting the sport front sway bar and the sport or maybe bigger rear bar too.
Thanks for any input.
Old Feb 13, 2019 | 03:00 PM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
The springs ARE different. It's the sport springs' difference in height (10 mm) that gives the car a slightly lower ride height compared to the non-sport springs. They are firmer, too.
Your question is whether you need to go to a stiffer spring, ostensibly because you've read that they are matched with the shocks and you are buying replacements intended for Sport and JCW application.. Strictly speaking the MINI Sport springs and shocks *are* matched. The common wisdom is that if you buy lowering springs you need to buy matching shocks since the shocks are tuned to provide maximum jounce control (in both compression and rebound) for a specific height and firmness of spring. But....it's only 10 mm difference (less than 0.5"). I say go ahead and buy the new shocks and I doubt that buying new springs is absolutely required. This will horrify the purists! ;-) You might even find that your customized solution is a better compromise when compared to the overall firmness of the sport suspension (which I have). I'm going to guess that you'd have to have a very finely tuned butt-meter to tell the difference.
Let us know how the Bilsteins work out!
Old Feb 13, 2019 | 03:42 PM
cooper48's Avatar
cooper48
I have the Bilstein B4s on my R53 MC40. It has the Sport "Plus" suspension which is approx. 20% firmer (springs than the Sport only). The B4s work great on my car, and with the addition of non-run-flat tires, the ride is totally acceptable.
Old Feb 14, 2019 | 10:17 AM
RCRacer's Avatar
RCRacer
Good info. I'm going to order the b4 struts and go from there.
I'm very tempted to do springs too so I don't end up having to pull the struts twice. Any input on springs? All I can find are aftermarket. H&R, NM, Eibach and Vogtland. $220-$290. I would be ok with a little lowering, but I don't want a harsh ride.
Old Feb 22, 2019 | 12:36 PM
Saltysalt's Avatar
Saltysalt
honestly the sport springs dont offer much difference between the sport and non sport, you just get that slight lowering effect. I have 2 R60's in the driveway, one with the sport and one without. the biggest difference comes from the rear sway bar which is 1mm larger, but even still not worth swapping for that. if the b4 struts allow for lowering springs you can opt for them, but most lowering springs will sacrifice ride quality for lowering. i thought about going to lowering springs route, but ima just opt for coilovers.
Old Feb 22, 2019 | 12:54 PM
eric.stewart
@Saltysalt They *are* somewhat stiffer. Maybe not by much. Agreed about ride height. As I said up a couple of posts, it's only 10 mm. Not much.
As for lowering springs, I couldn't agree with you more! I had a set of H&R Sport springs for my TT. They were supposed to be properly matched to my shocks (they were NOT!) and the promised lowering of approximately 1" was more like 2" and the ride was miserable. I ended up swapping them out.
I say go for the Bilsteins, too, based on others' recommendations + yours.
gbuff1
Jun 19, 2015 09:06 AM
Manny_cooper
Suspension
Oct 29, 2012 04:00 PM
MiniGB06
Suspension
Nov 7, 2009 06:04 AM
MiniJayhawk
20
May 20, 2008 09:27 AM
jeremy99
Feb 1, 2003 03:53 PM
