turning but not firing
Old Jan 27, 2019 | 05:50 PM
kayer56's Avatar
kayer56
Hello,
i have a 2008 mini cooper s r56. yesterday morning i started the car to warm up because its winter and its cold outside. I had to turn off the car and then when i came back a few seconds later to start the car, it wouldn't start. it turns over but it just wont fire! no warning lights
battery is brand new, spark plugs are still good changed one coil. and still nothing.
thank you
kaye
Old Jan 30, 2019 | 07:05 PM
mkov608's Avatar
mkov608
Hi Kaye. Your no start problem could be caused by many things, so you'll need to start by getting it diagnosed. Will you be doing the diagnosis or will you be taking the car to a shop?
I would look at the basics first ... is the sufficient fuel in the tank, are you getting sufficient fuel pressure to the fuel rail? Your spark plugs may be good (good not defined), but are they firing? Are they firing at the right time?
How many miles are on the car?
Old Feb 4, 2019 | 10:33 AM
kayer56's Avatar
kayer56
i just checked the fuel rail pressure on the torque app. it indicates its at 82.7 psi
is that normal?
Last edited by kayer56; Feb 4, 2019 at 10:55 AM. Reason: added photo for reference
Old Feb 6, 2019 | 08:17 PM
mkov608's Avatar
mkov608
Was that reading with the engine running?
The high pressure fuel pump should produce 725 PSI at idle; reference is below.
https://www.newtis.info/tisv2/a/en/r...ystem/FaFDXtpV
G3NSM0R3S
Sep 30, 2015 11:57 AM
vange234
Mar 8, 2013 10:12 AM
flyboy2160
May 27, 2010 06:40 AM
STEWIE
Detailing 101
27
Apr 25, 2007 08:26 AM
