Steering Angle Position Sensor R53
Old Jan 19, 2019 | 11:08 AM
Tombstone's Avatar
Tombstone
Has anyone had any issues with the Steering Angle Position Sensor on their R53 ? My R53 shows DTC and TPMS light after an alignment? Thanks...
Old Jan 19, 2019 | 11:45 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
yeah, reset it. Use inpa or ista/D
Old Jan 19, 2019 | 12:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's possible I would code and calibrate it.
Old Feb 18, 2019 | 04:10 PM
Tombstone's Avatar
Tombstone
[QUOTE=WayMotorWorks;4445138]It's possible I would code and calibrate it.[ Reset it with the Swaben Pro Scanner but, took a while due to the instruction booklet was real vague...Thanks
Old Feb 20, 2019 | 06:50 AM
Glad it worked for you on the reset.
Old Feb 20, 2019 | 12:11 PM
gpskipton's Avatar
gpskipton
The same thing happened to me after an alignment. They goofed and the steering wheel was a few degrees off when driving straight. A collaboration would have probably worked, but I did not want my steering wheel off. I took it back and they got it re-aligned close enough for the error to go away right away on its own.
Old Feb 20, 2019 | 12:23 PM
Sayvion Ralph's Avatar
Sayvion Ralph
Mine came on after I adjusted my camber in the fron and changed tie rod ends but once I got an alignment it went away
tag1260
Apr 12, 2018 06:25 AM
Lost in Mini Land
Mar 22, 2007 06:52 PM
holdenontoit
Feb 5, 2007 01:27 PM
minifox2
Jun 2, 2006 10:40 AM
NekoWoman
May 8, 2003 05:49 PM
